Looking for first tranctor - advice?!?
DRuh63
New User
Hi all, I am looking for my first tractor, most likely a sub-compact or compact, mainly for snow removal in my neighborhood. I have a small lot, and neighbors to help. We have tons of snow as we are in the mountains in Washington. I have been researching Deere, LS, NH, Mahindra, MF, etc. I am price sensitive since this will be primarily a snow removal tool and I don't have a farm. It seems difficult to find any meaningful head to head comparisons on new models.
I need the bucket, front snow thrower is all, not too complicated or fancy. Quick disconnect of course and HST.
I am leaning toward MF, NH and LS currently. Any constructive comments would be more than welcome. Thanks for your input.
What dealers are close by ? Deere and Kubota would be my first choices.New Holland 3rd. Price wise finding a used one with low hours would be best deal. Many of these type tractors the yuppies trade them off very often like cars.
I like my Fords but I don't care for Fiats. Kubotas are the cheapest by far to own. Finding a good deal on a used one though is extremely difficult, because of how they hold their value.
I'm sold on Kubota but your selection of nearby dealers will be influential.
Try tractorbymet.com.
Dean
I have a house at 8000' in CO. I use a 1948 Ford 8N, with a scraper blade, small front loader, and put chains on the tires. I have 260Lbs on the top of the scraper blade for balance.
Never been stuck, never found a drift I couldn't move, never had my tractor not start because some fancy electronics failed. Two years ago, I pulled my neighbors 2016 Chebby 4x4 with a plow on the front out of a ditch. He didn't even give me a tip.
It lives outside, but under a carport to keep most of the snow off it so I can get in and out.
YMMV
I have a couple of Kubota tractors for sale, a M6800 and L2250. Both have quick tach loaders, both very low hours. I am in Minnesota so probably too far from you. I have been very impressed with Kubota.
I don't have a love or hate relationship with any color tractor in this area. As others have said go with whatever dealer has the best service in your area. Just a couple things to think about. You mention wanting a front loader and a front snowblower. You probably already know this but just in case. You can't run both at the same time. With that weight on the front you will need rear ballast. Cuts are notorious for being light in the rear end. You might want to think about a rear mounted snowblower. It will give you the rear ballast you need and will let you use the front loader at the same time. The drawback of course is when running the snowblower you will have to be turned around looking behind you constantly. Another thing to think about is to match the tractor to the job you want it to do. Don't settle on a glorified lawn mower because it's cheaper and expect it to bust through 6 foot snow drifts. Gather information on all the dealers in your area and sit down and compare them as equally as possible. See which ones offer more options that you want. This is a great site but most of the experts here are more into bigger tractors. You might also try another site called Green Tractor Talk. They specialize in smaller tractors. As the name implies they are a more of a JD based site but there's still a lot of guys over there that would be happy to help out regardless of what color tractor you settle on.
From the description of what you will primarily be using it for, you might want to consider a skid loader. Front mount snow blowers are easier on the neck and back.
Just my $.02.
Mike
I understand peoples concerns about a nearby dealer but, I have had a Kubota since 1989 and never have needed a dealer. Got cross references on filters and that is all I have ever needed. A B1750 hydro xmission and 4 wheel drive is the best answer.
I have a 25 horse 4 wheel drive Kubota with 5' rear mount snow blower. Great at clearing snow.
Don't have big area to blow clear, but if I did I would have tractor with a cab. You can get mighty
wet and cold very quickly if the wind is blowing at you. Dad bought this tractor new in mid 70s, I
bought from his estate. Put a water pump on it 2 yrs ago. Kubotas are long running trouble free
tractors.
DR I need to ask (and it is your business) you did not mention the LEADER in the compact tractor market. Kubota is the solid choice. Do you have a Massy Dealer or why Massey. In the compact tractor market over all they have less than 4 % of the total market. Was there something that make you look a Massey. REALIZE this IF you can compare tractors feature for feature, things like transmission, lift capacity, ect prices are going to be pretty much close. Brand does make some difference but features will make more difference. KUBOTA JOHND DEER and most others make a economy tractor but you will give up things like hydrostatic transmission, slide out lift links, good seat, better instruments, Do your home work or get someone that know tractors. LS would be way down my list. Lack of dealer support and resale.
I have to chime in with Pat Sublett. If you have a Kubota, unless it is over twenty years old, what is the importance of a nearby dealer?
Couple things: I have a 4020 with a rear mount snow blower and it works great. A loader on the front would be better. 4 wheel drive even better
although the blower gives plenty of traction and I have yet to use chains. A cab would be even better as blowing snow in the wind is no fun. 1
caution, watch the rocks and dirt. It blows them too and doing a favor for the neighbors but also doing damage is a real quick way to make you
wish you hadn't offered.
Got a Branson dealer handy? I have 2 I bought new, '07 6530C (65 hp) I liked so well, I added a '16 2400 (24 hp) when I wanted a small
tractor to do odd jobs around the place. Both have more than enough power for the jobs at hand. Both FEL, diesel and 4wd...which is the
norm these days. Tough machines with Cummins licensed engines.
(quoted from post at 11:29:30 09/22/17) Hi all, I am looking for my first tractor, most likely a sub-compact or compact, mainly for snow removal in my neighborhood. I have a small lot, and neighbors to help. We have tons of snow as we are in the mountains in Washington. I have been researching Deere, LS, NH, Mahindra, MF, etc. I am price sensitive since this will be primarily a snow removal tool and I don't have a farm. It seems difficult to find any meaningful head to head comparisons on new models.
You might do better on a non-antique tractor site like tractorbynet.com
Nerest dealer not a good choice, best dealer is better even if it means a hundred mile farther to travel. And we have more Kubota dealers than anything else. As said cab and 4 wheel drive. Some of those models you are looking at I never heard of so not something I would even look at.
(quoted from post at 07:14:32 09/23/17) Nerest dealer not a good choice, best dealer is better even if it means a hundred mile farther to travel. And we have more Kubota dealers than anything else. As said cab and 4 wheel drive. Some of those models you are looking at I never heard of so not something I would even look at.
How in the world would he select the best dealer?????? If they claim to be best does it make them best? Or is there a state by state sweepstakes that I have not heard of? If someone spends megabucks and gets elected to a major office does that make them best?
(quoted from post at 12:07:37 09/22/17) I don't have a love or hate relationship with any color tractor in this area. As others have said go with whatever dealer has the best service in your area. Just a couple things to think about. You mention wanting a front loader and a front snowblower. You probably already know this but just in case. You can't run both at the same time. With that weight on the front you will need rear ballast. Cuts are notorious for being light in the rear end. You might want to think about a rear mounted snowblower. It will give you the rear ballast you need and will let you use the front loader at the same time. The drawback of course is when running the snowblower you will have to be turned around looking behind you constantly. Another thing to think about is to match the tractor to the job you want it to do. Don't settle on a glorified lawn mower because it's cheaper and expect it to bust through 6 foot snow drifts. Gather information on all the dealers in your area and sit down and compare them as equally as possible. See which ones offer more options that you want. This is a great site but most of the experts here are more into bigger tractors. You might also try another site called Green Tractor Talk. They specialize in smaller tractors. As the name implies they are a more of a JD based site but there's still a lot of guys over there that would be happy to help out regardless of what color tractor you settle on.
Thanks for the input. I have a small lot, under half acre but have a good amount of snow. I have thought about the rear mounted thrower but having had back surgery last year due to a shovel full of snow my thought was to get the front mounted. I'll check out the Green site and see what they have to say. It seems to me that most are equal except on price and support. Doesn't make it easy. Thanks again!
Haven't looked at Branson. I have JD 30 miles away, NH, MF Kubota and JD within 50 miles and LS at about 70. That's all I know of in the "immediate" area.
I mentioned Massey simply because there are MF, Kubota, JD and NH dealers all about 50 miles from me and in the same town. I know Kubota are very popular but when I spend half my lunch hour on the lot and in the sales floor and not one of 4 sales people greeted me it kind of soured me on the brand. I may reconsider. The MF dealer in town quoted some decent pricing and took time to figure out what may work best as did the JD and NH people. It seems to me that most things are comparable except pricing and support. Thanks for your input, it helps!
(quoted from post at 14:36:43 09/27/17) I mentioned Massey simply because there are MF, Kubota, JD and NH dealers all about 50 miles from me and in the same town. I know Kubota are very popular but when I spend half my lunch hour on the lot and in the sales floor and not one of 4 sales people greeted me it kind of soured me on the brand. I may reconsider. The MF dealer in town quoted some decent pricing and took time to figure out what may work best as did the JD and NH people. It seems to me that most things are comparable except pricing and support. Thanks for your input, it helps!
It seems that you need to spend more time.
