rlegare1944
New User
I have a 1972 Ford 4500 3 cyl diesel backhoe. I am trying to remove the oil pan. I have removed all retaining bolts visable, and four 5/8 bolts which were at each end of the pan going into both the front end, and the lower transmission housing. This pan is cast iron and I expected it to be an easy job with all the weight. I cannot get any movement from the pan. Did I miss something? The service manual I have is for the 2,3,4,5,,and 7000 models, but the oil pan does not look anything like the one I have on my unit. If the gasket is seized to the block, is there a way to break it loose without damaging the block? Help, help, help, winter is coming on soon.
