ford 1520 2wd no move
rwhoffman759
New User
Long story short. brother borrowed tractor to mow. Came back broke. Will move if diff lock is applied but stand still if diff lock not used. Jacked up tires wheel spin untill apply pressure to them. Thinking rear diff but any other suggestions ?
(quoted from post at 19:06:39 09/21/17) Long story short. brother borrowed tractor to mow. Came back broke. Will move if diff lock is applied but stand still if diff lock not used. Jacked up tires wheel spin untill apply pressure to them. Thinking rear diff but any other suggestions ?
Painful lesson learned. Don't let others borrow your equipment! Sorry for your troubles, but if your brother(s) are like mine they would break an anvil, so they get nothing from me. I might do the work for or with them, but no borrowing.
Had better pull the rear cover off, something wrong with the Spiders or axle gears..
Something is wrong in the differential. COuld be broken spiders... but probably is broken bolts/rivets on the crown wheel.
Rod
