Replacement for Continental Z129 engines?
mogley
New User
Does anyone make a engine that would bolt right up for a Ferguson with a continental Z129?
I see rebuilt kits but what if the block is bad?
Thanks
No, not any aftermarket sources available.
Bad news, they are prone to crack.
Good news, there are a lot of rebuildable blocks out there, and the cracks can sometimes be repaired.
Continental made a lot of engines for many different applications. If you go looking for a block, make sure it is specifically for that tractor.
(quoted from post at 12:15:19 09/16/17) Does anyone make a engine that would bolt right up for a Ferguson with a continental Z129?
Thanks
Wouldnt it make sense for someone to start making a bolt in engine?
An adapter plate and components might be feasible, but to make an engine is dramatic. and for replacement in used tractors Nope.
Jim
Vapormatic makes a brand new Ford BSD444 and BSD333, new everything, not a Massey but aftermarket is making some engines new.
There should be a bunch on engines that will fit in a TO30. Massey 35's might fit as well, I'm certainly not an expert on Massey's.
(quoted from post at 17:51:12 09/17/17)
Thanks
Are you serious? Tool up to cast and machine an engine that they might sell 10 a year of over 20 years? Would you pay $5K for the engine, or more likely $20K? Because that's probably what you'd have to charge to break even.
