5625 oil leak....Just remembered something...I had a 4625 for years, had an issue once with major oil leak- on the hydro pump that hooks to the engine. When that unit gets worn, it leaks high pressure oil into a chamber with a thin steel cover on it. Cover is just over an inch square? Cover bulges. Straightened it once, put in new gasket, bulged/leaked again. I replaced the cover with heavier HM one, maybe quarter inch thick. Didn"t leak before I traded the machine, maybe two years later.
Drop the belly pan to see where the leak is coming from. Mine leaked enough that it wouldn"t move itself.
