Allis Chalmers D17
They have the hyd pump on the side of the tractor and the loader has to be a little wider on that side . Dad has an 800 series Kelly on his.
A 400 or 500 AC was the factory fit. I have a Paulson off of a Farmall M on mine. Took a bit of fab work but it fits. Only the series 4 had the external pump on the side. Any other will really need a stand alone hyd pump for modern work. I put a front mount pump on mine.
AaronSEIA
You can add a front pump- the crankshaft pulley has 4 holes, threaded to bolt on an adapter drive.
