TractorLinks.com
Tractor Talk Discussion Forum
Agrodoctor parts from across the "Pond"
4435
09-12-2017 07:57:16
Need some parts for my illegitimate John Deere combine. Mother Deere about a grand for three sprockets. From the EU probably $300 Freight included. Anybody on this or the other side use them, Quality? Good bad experiences. Thanks Tom
4435
09-13-2017 10:33:24
 Re: Agrodoctor parts from across the in reply to 4435, 09-12-2017 07:57:16
A 4435 was meant to replace to 4420 it is a rebadged 9,10,11 something series from across the Pond. This one is hydro with RWA added.
I have done the sprocket blanks once. Saved nearly a grand then too. Two of the sprockets are pretty involved and my machinist has had a stroke from which he never regained his dexterity. With custom rates at $75-100 an hour. Thought this might an alternative.
Couldn't drag the Pictures over so here are the links.
https://agrodoctor.eu/straw-walker/103771-33-tooth-roller-chain-sprocket-33t-z33-for-john-deere-combine-straw-walker.html?search_query=Z11690&results=1https://agrodoctor.eu/thresher/91772-16-tooth-chain-sprocket-for-john-deere-combine-threshing-drum-shaft-d36mm-16t.html
Tom
JD Seller
09-12-2017 15:15:42
I have turned off worn sprockets and put back weld on sprockets on a lot of JD combine drives. Check with a local machine shop they would be cheaper than either price you quoted.
DeltaRed
09-12-2017 11:55:37
What model combine? there are several generic'weld a sprockts' that could possibly be made to fit.Doesn't necessarily need to 'genuine Deere' to work.Give more info. A few pics will help us help you.Sometimes a bit of creative engineering is needed on 'oddball' equipment.
