Ford Front End Loader
CCINGI
New User
I have a Ford 850 tractor that has a front end loader that I am assuming is a 703 (the plate is too worn to tell) based on pictures I have seen and info I have read. The hydraulic pump for the front end loader is leaking and I can't seem to find any seal or rebuild kits. I'd appreciate any guidance on where to find parts. Thanks.
Nancy
Most of the time it is cheaper to just buy a new pump instead of trying to rebuild the old ones since many cannot be rebuilt. A new pump is around $250 or so form a place like the surplus center
You can measure your old pump, center to center of the mounting bolts, shaft diameter, keyed or splined, inlet/outlet size, gear size. You can also try to find a local hydraulic shop, they maybe able to identify the pump, and find a rebuild kit (and rebuild it), or find a bolt on replacement pump. A newer replacement pump will probably be the cheapest way to go unless you just have to have it all original.
