2wheelgnnr
I have a 53 Jubilee with a lever right under the seat(between your legs) so to speak. small lever and its attached and seems to affect the external hyd. Port. You can just lift the handle and it presses in a bar/pin. Does not Appear to be the Selecto switch I see some had and the lever might temp cut off the flow to the external hyd port. I dont use this port as of yet so no clue what it does. Any ideas?? not a lever as you pull up and it when you let go comes right back down so its use is Temporary so to speak thats why Im thinking a temp bypass valve or something of some sort.
