(quoted from post at 00:18:10 07/26/17) A Mercedes vehicle that most people can afford haha. Pic is funny but to be fair that car hit a concrete barrier at 70MPH, the doors even stayed shut, left side opened with the handle, pass side opened and still shut. Those little cars actually scored top ranks on crash tests, much better than a lot of cars/trucks 2 or more times their size. I still wouldn't have one though, I don't see any benefit, good fuel economy but not great either.
Scored better? You should take a long look at the ratings/test. "In their size class". IMO all should be tested to the same standard, then we will see where they really rank. Then too the tests are set up to certain criteria to project what they want you to think.
Seen the aftermath of a wreck where one of those tangled with a mid sized car. The folks in the little thing died while the people in the mid sized car were only injured.
Rick
(quoted from post at 05:16:46 07/26/17) This is why that happens. They are the worst driver's on the road. They must tell them they are indestructible so don't be afraid. I've also never seen one that didn't dig track too. They must not check the alignment before they sell them.
Smart car
(quoted from post at 21:49:23 07/26/17)Scored better? You should take a long look at the ratings/test. "In their size class". IMO all should be tested to the same standard, then we will see where they really rank. Then too the tests are set up to certain criteria to project what they want you to think.
Rick
Well, you have to take their unbiased scores for granted I guess, all vehicles go through these same tests and are graded on the same standards. the head-on impact test (40% frontal impact) is the only test that they rate vehicles in weight classes, all other impact tests are equal and comparable. What standard would you prefer them to be tested with to be "fair"? Keep in mind a 1700# vehicle has far less kinetic energy when hitting a solid object than a 7500# vehicle would.
If you want to test a 1700# pound vehicle colliding into a 7500# vehicle, then by weight percentage difference you would need to test the 7500# vehicle against a 25000# vehicle.
Bottom line is small or large vehicles aren't always safer or more dangerous than the other, it depends on many things but one is what they crash into, unfortunately that's not usually a decision the driver gets to make.
