One of This Week's Projects
Jeff NWOH
I posted a while back about my offset flail mower I bought on the cheap at an auction. I really needed it centered so I can haul it on my trailer. I had the week off work so I spent a couple afternoons on it.
I cut all the mounts off and shifted the 3 point and gearbox assy around 20". I then extended the driveshaft tube. I didn't have a long enough scrap of 2.5" pipe to make it in one piece, so it has a splice. I figured I didn't have anything to lose by trying to stretch the driveshaft, so I went for it. Solid piece of 1.5" with a 1.125" hole bored in each end about 2" deep. I then cut the original in 2 and pressed it all together and welded. It only has a few thousandths runout so should be fine. Making the tube and driveshaft saved me around $350.
I have a couple bearings for the rear roller and a new set of knives on order. I may even blast it and paint it. Should make a nice mower now that I can haul it without leaving a trail of broken mailboxes behind me.
I don't remember who suggested Montage for the parts, but I thought they were reasonable. Even gave me free shipping.
Very nice work. Those offsets drive me nuts. I reconfigured a brand new Woods belly mount mower bracket to center the mower under the tractor.
That looks to be a Mott Brand flail mower. I have a 5' one that has been in service since 1987. It has had 2 bearings in the rear roller and one bearing replaced on the drum. It does a goods job.
Would it have been possible to add another centered three point hitch for transporting, and leave the off set hitch for normal operation?
Wow, nice job! Clean-up and paint and that will be a great looking mower. Even if you don' paint you have a nice mower. Paul
