electrical gurus
55 50 Ron
Have any of you worked with a TRANSPOO D100? It's a type of electronic "cutout" and I'm wondering what type of measurements a good one should have out of the circuit. It has 3 terminals BAT, ARM and GND (case)
Long term I'm planning to change it to a VR, but for now I'm curious as to if it's good or bad.
Thanks sparkies
Ron
As a cutout what is this supposed to be sensing? I don't know what this is. I was wondering if the "ARM" is the output that enables something based on an input like pressure, position, temperature, etc.
Paul
That's the correct photo, but it says voltage regulator which I don't believe it is for only a two=terminal device. I measure 1.48 M ohms in one direction and open in the other. Seems high R for a diode. Open from both ARM and BAT to GND. Measurement done with a Fluke 73 III multimeter on Ohms scale. I think that meter uses a 9 Volt battery for the Ohms scale.
Those numbers are the same. A million ohms is equal to no connection. so it is open in both directions. Jim
Jim, Thanks. I think I'm on the right track trying to find a leak path that slowly drains the battery. This tractor is wired wrong and I'm correcting it and adding a real regulator in place of this TRANSPOO "piece of junk"
The tractor is an Oliver 70, positive ground, 6 volt system, magneto. (It's a 1936 and owned by Farmamerica)
When you use a meter such as a Fluke to test a PN junction, make you use the diode setting rather than the ohms setting. If my memory serves me correctly, The ohms setting uses a lower voltage than the diode setting
