(quoted from post at 14:30:59 07/18/17) The 48 is the correct loader for the 2510, the 148 would be a better fit on 4020..
(quoted from post at 15:59:06 07/18/17) I would not want a 48 on 4020, just too easy to break.
(quoted from post at 18:12:25 07/18/17) I felt the same way, I put a 145 loader on my 2510 although I would have preferred a 146 loader. I also fabricated my own mounting to the rear axle. I see opinions vary, but putting that beam to the rear axle really stiffened the whole system.
The only negative is you will not get the height and reach of a 148 loader. How will you use he loader?
Paul
(quoted from post at 01:50:52 07/20/17) The problem with a 148 loader on a 3020 is that the 3020 engine has only two mounting bolts at the rear of the engine, vs four on the 4020...
