Ford 3600 Power Steering
I have a Ford 3600 diesel tractor with power steering. When the tractor is running, power steering fluid is being pushed out the filler cap and the breather of the system. Any ideas on the possible issue; what is the cause, and how can it be fixed?
Change the filter!! I went thru the same thing with my 2600. I also changed the seals at the same time.
Had that problem on a 4000. Been so long just forget details but think only filter. Know we did not to anything to pump for seals.
The media is parted from the end plates of the filter... Change it. If the shaft seals were bad, the oil would be going into the engine, not
out the breather.
Rod
