olgentdc
I found a gallon of 303 hydro oil that was left and forgotten under a hay wagon for too long , water/condesation had
infiltrated , i noticed after i put this in the Yanmar that it slowed the hydraulix .. so i quit using it ,.. it really had no
seperation so i assumed it was just infiltrated thru the cap ,, The Infiltration was probably Algae ,. anyeway ,since this
modern gas is SO Dry, i ASSUNMED the extra lube would help the gasser tractors , i poured the 303 in my 730 Case Gassr,. , it
was nearly 2/3 full , , i didnt get around , the field before it was starving for gas ,,. blowed out the line ,, yucky sea
anemene algae stuff floating in the sedimet bulb , ,poured a qt of seafoam in there ,, did seem to help, after 2 stops and
more of that algae , i opted to add the yellow heet ,. still not much improvement ,, that algae would stop the valve on the
sedimt bulb ,,. red heet seemed to make little difference ,,.,.but at least it was not stalling for 10 minutes or more while i
was spraying ,,.. yes ...mite have been as well off to go get new gas and pull that shyt out of there,. but we was gonna get
rain at sunset i wanted to get the cukleburs knokt down ,.. hindsite says that was the rite dicision ....got the sprayin done a
couple hours before sunset...
