So, it appears that I've found myself looking at a rebuild for a naturally-aspirated 4 cylinder diesel, which I really didnt want to mess with, but it is what it is.
Regardless, I'd perfer to stick to an in-frame overhaul if possible.
When I take this thing apart, what should I be looking at/for in regards to the inspection of the crankshaft, to tell if it will need to come out and be reground, or if I can simply give it the fresh bearings that come with the wet sleeve overhaul kit, and continue on with life?
Thanks in advance...
