Oliver Super 55 and 3241 plow update
ed in cny
Back last week I posted issues with my tractor and plow. Had many respond but wanted to let you know what the issue resolved itself to be. The hitch point where the three point arms attach to the plow had gotten out of angle and was causing the plow to ride way left. I adjusted it to be more in line and it came back behind the plow. I then though the pivot point was wrong so I changed it to another hole put is back straight across the plow and it was back to worse. I went back to the first set up and back it came around to behind the plow. There is still some set up to get it where it ought to be but it's back where it should be. It isn't pulling on the chains nor are the three point stabilizer bars needed. A good cleaning up of the plow will get it to run even smoother. It was shinned up pretty good but could be better. It pulls now behind the plow and with much less effort unlike before from the tractor.
