John Deere B wont start
Roate67
New User
My John deere b wont start replaced plugs and magneto parts including the cap what should be my next steps?
As with any gas engine trouble shoot then parts NEVER the other way around you your likely to add problems not fix them
#1 make sure you have a good blue/white spark at both plug wires that will jump a 1/4 inch gap or more. And on a mag make sure the impulse is working
#2 pull the carb drain plug and make sure you have a good steady flow of gas that will fill a pint jar in under 3 minutes and yes catch it to look for dirt/rust/water.
#3 when was the last time you serviced the air cleaner it could be full of mud and water that will keep it from starting
What was it's condition before you started working on it? What's the back story? How long has it sat, or did it run and only stopped when you started working on it?
