Need help idetifying an item
Oakley1919
New User
Can anyone help me identify this part? The mount is broken and I was looking into replacing it. All I know is it has to do with the fuel. On top it has a return line back to the fuel tank.
Thanks for any help
Thank you for all the help! I will order a new one. I really didnt want to weld it but I thought that was going to be my only option. The link was perfect!
I wouldn't spend the $ to buy one.
Those were used on the early models but
discontinued.
Later models just had a T in the line and
sufficed.
Yes.. on all later models, a tee was introduced as the line to the thermostart was adequate for a reservoir for cold starting the tractor... its simply a small holder of diesel fuel in the return line that fills up and hold diesel to allow the thermostart to fire up and heat up the manifold when used for pre heating or cold starting.
Thank you all for the information and help. While it may not be needed since it was discontinued, I went ahead and ordered one. I dont want to play too much with stuff I dont know much about and screw something up for the long run. This all has been very inciteful and the website provided will be a big help with the random stuff that comes up.
