How many horse to pull 12 row planter?
Brown Swiss
Answer: 2 LOL
Those are some tough horses! Obviously photo shopped as that tongue weight of the planter would have those horses up in the air...lol!
I have seen the Amish pull a round haybaler with a mounted motor with a team of 8 big draft horses. But that was on flat ground.
A few years ago I stopped along a highway and watched a team of 4+4 pulling a 6 row planter. At the end of each row, the driver would stop, fire up a gas engine with hydraulic pump to raise the planter, shut the engine off, and turn around for the next rows. As soon as the planter hit the ground, those horses were gone. Quite a sight to watch.
(quoted from post at 12:25:53 04/27/17) Those are some tough horses! Obviously photo shopped as that tongue weight of the planter would have those horses up in the air...lol!
Maybe the hitch on the dolly is adjusted to prevent that! :roll:
Alright on the flat but going downhill i know the pull carts have brakes but it could be a ride . But it looks like Photoshop.
A few years back going through Iowa I seen a bunch of horses hooked to a no-till 4 row JD 7000 planting corn on a field of sod. They were planting the field in a big circle and not lifting the planter.
Look at the hitch wt is on the axle of the cart. The Amish mite be silly the way they cheat to not use a tractor but very smart when making stuff to use modern machinery.The have used motorized carts to run all sorts of stuff you should see the cart used to make a two row corn picker work.
