How about some dual pics?
Eldon (WA)
Slapped these on the Deere a few minutes ago. Band duals go on pretty easy...sure makes the tractor look mean!
As I was installing the duals on the 2090 Case a couple of days ago I got to thinking, this must be about the 36th year I have done this job
since I bought the tractor. I take the duals off for winter use and then get them back on again for floatation in the fields in the spring.
You can hardly tell in this picture from 1989 but I had the duals on here. Just finishing up seeding some potholes that I couldn't get into
with the dual Seed Rites so I was pulling a single unit. (11 feet). Not quite as wide as the duals.
Yeah I need to get my grass seed in...and it is pretty wet, but supposed to rain all next week. I am about 12' wide...same as the drill.
Put them on in the spring for a little flotation in the mud. Takes some thinking to remember that your 12' wide when it comes to driving on the road and navigating through gates.
(quoted from post at 20:16:48 04/22/17) Seems like duals would be hard on the differential when turning.
Not sure about the differential, but you do have 3 out of 4 tires scrubbing when you turn....
(quoted from post at 22:22:32 04/22/17)
Be a few more than 3 tires "scrubbing" here...
This is probably 40 years ago but they are duals. My dad rented this farm and the previous guy must have gotten stuck. Told my wife to get as close as she could to work the tracks shut. She did-got 2 inches of rain that night.----Tee
This was taken in 1974.....My 856 IH with 24.5's on the inside and 18.4 duals with the horsepower
to turn them.....This tractor seldom got stuck..
HUH---Egging, It is one of the reasons I can't hear. You could stand up in it. I bought it that way from the sales in Grand Meadow Minn.---Tee
Here is my 100 horse Case IH, just put the duals on yesterday. I use this for planting and cultivating. Loader on for snow in the winter.
4450 with front duals, drive wheels from old Case combine. And the M2 combine with straddle duals.
Randy - I thought sure you'd post the picture of your father or uncle by the old tractor.
Took a rear view shot before the duals came off tonight...kinda wide to be moving down the road on a trailer....
Obviously you're a Bolens fan, I see several in the backround. I like them too, still use a 1050 for some things rather than abuse my JD hydrostat.
You're not doing too much heavy work with this, are you? Those rear ends aren't really meant to be set out that wide. Just want to be careful with doing any heavy
work with it setup like that.
(quoted from post at 20:38:41 04/24/17) You're not doing too much heavy work with this, are you? Those rear ends aren't really meant to be set out that wide. Just want to be careful with doing any heavy
I was just pulling a drag with the duals on. I bought this tractor with 4 1/2" JD factory spacers on the rear w/ 320-42 radials. I had a set of custom made 5" aluminum spacers/adapters made so I could run a standard wheel with 5/8 studs (which I have a good selection of different sizes). I also needed to get the rear wheels out to 8' to run my 8' Bush Hog.
