MattCatlin
Hi guys, I have an old 1962 4010 diesel. She is leaking fluids really bad, I got to put 5 gallons in every time I use it. I thought it was mostly from the remotes, but I see it running out by the front pto shaft. I am out of clutch pedal adjustment and last year it was slipping some, this year it hasn't seemed to. I'm going to try to find someone to split her and redo the seals and clutch. While it's apart what else should I have replaced or looked at? The motor runs like a sewing machine, other than the usual worn out shift boots it seems to be a real good runner. I'm always amazed each spring to come out hook the batteries and have her immediately fire. She sits outside.
Thanks for the advice.
