I have an IH Cub, and the carburetor (it's IH brand) has two plugs in the bottom. One is in the Bowl of the carb, for draining gas. The other is on the bottom of the throat (where air is brought in). This plug has a small hole, maybe 1/16 inch or smaller, drilled through it. there is no obstruction at all. I can literally see through it. Is this normal? Ive not seen this on any other carbs on any of my tractors.
This plug with the hole is behind the choke plate, so even at full choke, air can pass through. Wouldnt this affect the performance?
and, yes, the tractor runs poorly as it is.
