I was useing my 4020 and the lost the pressure on clutch pedal . There is no adjustment in the pedal either. Will the clutch go out all at once like that?
There is a spring under the platform but I assume you already know that. Does the clutch work at all? As to your direct question I cannot answer that but I assume it could given the number of components between your foot and the pad.
Paul
ASSUMING it's a synchro tranny, it's likely the throwout bearing stuck and wore the tips off of the clutch release fingers. Did you hear any unusual noise for a period of time before it failed?
Take the inspection cover under the clutch housing and take a look up there with a good light and you should be able to confirm that, plus some pieces or grindings will probably fall out.
