Massey Ferguson 135 hydraulic problems
I have a MF 135 that lost all and any lift arm movement yesterday, will not move at all. Yesterday i block a auger up will doing work maintenance on the implement and after finishing tried to lift the arms to remove the block and it would not move at all. U can lift the arms manually with no resistance at all. Any Ideas??
Does your pto work? The pto and the hydraulic pump work of of the same shaft. If the pto works then it would have to be in the pump itself or maybe the stand pipe o rings? If the pto doesn't work it could be the coupler is sheared?
Steven
The control valve could be stuck. You will have to remove the round cover by your right heel to free it up.
If you blocked the implement up while it was on the arms and you have a 3 point lift system that leaks off when the engine is shut off, my guess is that you have air in your system now. Just drop the implement off and raise the arms several times by hand, completely up and let them down. Do this while the engine is running and the lift is in the up position. I've had that happen and it corrected the problem. By the way, you probably need to do a little work on your hydraulic system. Just my thoughts. Let us know what you find out. Keith
I assume that the serial number should tell me what pump I need. I noticed that pumps of this style have 10 or 21 spline cam shafts, could this be the only difference?
