Belt Lengths
David G
This is a front shot of the 961 I am fixing up.
The belts were all 3/8, should of been 1/2, I was surprised how much the length needed changed after putting on correct belts.
Like wise when you deal with worn pulleys..the correct size belt on worn pulleys will put you at the end of the tightener right off..and of course with the "V" of the pulley worn the belt will not hold ether...
