John Deere 60
Hemicar
New User
I bought a John Deere 60 and the fan bracket was cracked. I replaced it only to find out the fan vibrates excessively which is why the bracket probably cracked to begin with. Anyone know what might be wrong with it.
Also could be an issue of wear in the friction drive hub area causing the fan to run off-center.
The balls of the bearing at the end of the shaft have separated from the cage and are piling up together. Time to rebuild the shaft.
(quoted from post at 08:04:20 03/27/17) How hard is it to get the shaft out?
Green Magazine has a video that shows how to open up the govenor to remove and install the fan shaft without busting anything.
