This message is a reply to an archived post by Vincent0522 on November 02, 2016 at 20:39:38.
The original subject was "IH Drott Skid Shovel 340K3".
hello
any updates..../?
had to go look as you seemed so sure .....? that 1st photo from this angle clearly has the exhaust on the right....? that is diesel and it is an "A" so it is after diesel was offered.....it will CLEARLY have spark plugs wires distributor or injector pump on the right side
clear photos here
https://www.google.com/search?q=ih+340+photos&rlz=1C1GGGE_enUS520US570&espv=2&tbm=isch&imgil=yQeBaYJgvUN2TM%253A%253BHPoTGlIRcVotqM%253Bhttp%25253A%25252F%25252Fwww.tractordata.com%25252Ffarm-tractors%25252F000%25252F3%25252F2%25252F320-international-harvester-340-photos.html&source=iu&pf=m&fir=yQeBaYJgvUN2TM%253A%252CHPoTGlIRcVotqM%252C_&usg=__QyZAygj2glY0DXpW3i1Crt3bz_o%3D&biw=1024&bih=677&ved=0ahUKEwiWxeehpu7SAhUr5oMKHR6hDm4QyjcIMw&ei=25_UWNbrGavMjwSewrrwBg#imgrc=_
as to the no turn try adjusting the brake travel ...attached to lever under foot pad
hello
any updates..../?
clear photos here
