8 N tractor, 1943
Norm Stout
New User
My tractor worked beautifully in all weather and conditions.
Now she's broke.
Mechanic worked on it, I worked on it, put new parts on and she starts but won't stay running and sounds terrible when she runs.
Anyone out there have an idea what I can do next?
Norm........4-speed 8N's were first mfg in 1949. Your 3-speed 2N was mfg 1942-1948. Based upon yer complaint, my WAG (wild A$$ guess) is you've gottchur sparkies miss-wired. Probably #2 & #3 swapped. Yeah, the 4-nipple front mount izza bugger. Points are 0.015 and best adjusted on the kitchen table. Me? I'd clamp the corner of $1-bill between the points and pull. Polish the INVISIBLE CORROSION from between the points. Ennytime you have starting issues, replace yer sparkies (again?) Recommend AutoLite 437's gapped 0.025. 2nd advice, learn how-to adjust yer carbie. Set the down-pointing MAINJET to 2-turns and LEAVITT!!! Adjust the side-pointing idlemix fer FASTEST idle, NOT SMOOTHEST idle. Understand the difference??? Ennythang under 500-rpms is good. I once got my eazy starting 6-volt 8N to idle 375-rpms onna transistorized tachometer. .........HTH, Dell, yer self-appointed sparkie-meister
Simple way to remember is that the number is the last digit of the model year that the tractor came out:
9N: 1939
2N: 1942
8N: 1948
What people are trying to say is that you cannot possibly have a 1943 8N because they were not manufactured until the 1948 model year.
x2 on electrical or fuel.
This post is like asking Dr over phone what's wrong with me, I'm not feeling good?
Now that everyone has roasted poor Norm for the mis-identification, would any of the repair recommendations have been any different for an 8N vs. a 2N?
Yes there is differences especially between early and late 8N tractors with front mount or side mount distributor. Besides that electrical system is different.
A's Dell says check firing order. Then check fuel flow to carb. Then put a timing light on it and
see if the fire quits. Then go to N forum on this site and tell us what you saw.
Sparkie!!!!!!!!!! Carbie!!!!!!!!!!! At least you did not call it a Dizzy. And you correct him on year of mfg????
when I was a kid learning to troubleshoot an engine my dad gave me some good advise that has helped me for the last 58 or so years. He sail most carburetor problems are in the ignition system. So get your ignition in good shape first. Dell gave you some good advise.
Elmo
Check fuel by opening drain plug on carburetor. I hear there are a lot of bad condensers out there right out of the box.
Welcome to the forum Norm.
It does make a difference whether you have a front mount
distributor or a side mount distributor. If you have a front mount
I agree with making sure you have your firing order right.
Either, actually, but especially with the front mount.
Firing order is 1-2-4-3 Counter clockwise on either.
Very easy to get the #4 and #3 wires swapped on a front mount.
Points are often the cause of the issue. Especially if you got
cheap junk from TSC or similar. If they have a plastic rubbing
block you better keep a spare set handy.
Gap is 15 thousands on a front mount, 25 thousandths on a
side mount. Plugs are gapped at 25 thousandths on either.
Check out [b:8d64227c84]John Smith's[/b:8d64227c84] excellent site for Ford tractor ID's.
