Wisconsin V-4 question
Fritz Maurer
A VP4D equipped with a distributor has irregularly spaced lobes to coincide with the irregular firing interval of a V-type engine, which is 180, 270, 180, and 90 degrees. Yet, all the magnetos in the parts list have cams arranged to fire every 90 degrees. How does this work?
On a Wisconsin engine with 'uneven firing', magnetos run at twice the speed of a distributor. Half of the time the spark occurs at the end of the exhaust stroke. Crude, but it works.
All of the Wisconsin V4 engines are 90 degree design. To get an even-firing engine, there are changes to the crankshaft.
Yes, I have one of those little odd fire Wisconsin's fitted to one of my parade tractors, a steel wheeled 22-36 MD The mag runs crankshaft speed, and has the distributor rotor directly mounted to the mag rotor shaft, not the half speed gear driven rotor of the even fire engine. It sparks every 90 degrees of crank rotation, sparking 4 times on TDC compression to fire the cylinders, and 4 times on the exhaust stroke, the 4 wasted sparks.
