kleine39kermit
Yesterdays Tractors lists an oil seal,rear axle, inner (195555M1 for the TO-20 tractor.
My I.T. shop manual for this tractor says there is no inner seal, only an outer seal. The TO-30 uses an inner seal and you need to pull and repack the bearing with grease every 1000 hrs. So I'm thinking the TO-20 gets its oil from the rear end.
So does the TO-20 have an inner seal or not.
