Mike Conwell
New User
I have a Massey Ferguson 135 and it has an aux hydraulic valve mounted just to the right front of the seat. I have no need for this and its in the way getting on and off the tractor. I removed the valve but it has a couple of hy ports looking up with the seals on the valve itself. Also it has a tube about 1/2" in diameter that extends down into the tractor. This tube has an oring seal on the end of it that must seal in the hole the bottom of the tube fits into. I can make a flat cover to block off the ports but do I need also to block off this tube???? I am assuming this tube carrys hyd oil up from inside the tractor into the valve itself. How do you remove this valve if you dont want it on the tractor???? Anybody know ?????
