656 farmall hyd question
4520BW
Working on my father-n-laws old 656 that is leaking oil around the load control and lift levers. I need to remove the shafts that going into the housing. I removed the seat and top cover,and to access a roll pin book says to unhook a linkage and remove valve. Can anyone give me some ideas on what all has to be removed? Book is real vague.
The hitch cylinder and valve come out at an assembly to get at those lever parts. Pay close attention to just how that lift limiting link is installed so you put it back together properly. If I remember right, you will need to remove aux valves also, might be wrong on that though.
