2 pin trailer plug.
My 2N has had a 2 pin trailer plug on it since I got it ( 17 yrs ago) I have never used it. I want to use it now but cannot find the male trailer part. Believe me, I have looked . It is like the common trailer plug with 5 pins around a center pin. On my plug, one pin is hot, the other is ground. I don't want to change it out as many comments will recommend. Any help greatly appreciated.
(quoted from post at 16:56:20 01/12/17) My 2N has had a 2 pin trailer plug on it since I got it ( 17 yrs ago) I have never used it. I want to use it now but cannot find the male trailer part. Believe me, I have looked . It is like the common trailer plug with 5 pins around a center pin. On my plug, one pin is hot, the other is ground. I don't want to change it out as many comments will recommend. Any help greatly appreciated.
oogle molded two wire tractor plug see if this matches.
My 881 has the same two pin plug, it came new with it to supply power to trailer tail lights, haven't seen the trailer end of the plug in years but haven't looked for one ether.
https://www.rcpw.com/truck-accessories/trailer-connectors-2-pin/TC2002.html
googled 2 pin trailer plug.. is this it??
How about this
Just googled 2 wire tractor plug and several came up and I linked one. Now I can't get any to show. Weird!
Allis used a 2 pin plug in the 50's. We had a WD45D that had one we used to run the high speed wrap on the rotobaler....might be the same.
I did a search just for fun, and quickly realize you are gonna need to supply a picture of what you have, and or dimensions of what you have, metal or plastic, you gonna have to give us more to sort out the many, many possibilities out there.....
Paul
