TractorLinks.com
Tractor Talk Discussion Forum
Not quite a "yesterday's tractor"
Fatjay
01-10-2017 19:35:29
But you wouldn't know it when the previous owner stored it outdoors under pine tree's for 30 years. Panels faded badly, all bolts rusted. Broke about half the bolts getting all the panels off so I could paint them. Skinned a few knuckles too.
Making a cab, couldn't have it with fresh paint and have the tractor looking like crap.
Fatjay
01-12-2017 07:57:14
 Re: Not quite a in reply to Fatjay, 01-10-2017 19:35:29
I'll talk to the wife about it and see what she says. Any idea what something like that would cost to ship? Do you have any photo's by chance?
Fatjay
01-11-2017 13:13:48
Also where are you located? I'm in eastern PA.
tracy Brown
01-11-2017 16:46:41
 Re: Not quite a in reply to Fatjay, 01-11-2017 13:13:48
I am in North MS. I have had good results shipping thru Fastenal.
Fatjay
01-11-2017 13:12:01
I'm not sure what size the bolt pattern is. I have a spare set of front rims but hte bolt pattern is different. It's also different from the B7200 my father has. Same number of bolts, but different spacing.
Tracy Brown
01-11-2017 11:05:54
What size rear tires/rims do you want? I have a Kubota L3400 parts tractor with VG R4 tires/rims on the back. $400 for the Pr mounted and up.
Fatjay
01-11-2017 07:11:29
On my list is to get another set of rims and do 4 R4 and 4 turf so I can swap them based on the season. With 4wd not engaged, it shouldn't have any negative effect though, the only time 4wd is engaged is when it's slippery out, which should absorb any rotational differences.
I have to find a kubota dealer around here though, and hope they're better than the deere dealers. Deere around here has a motto of "If it's not new, we can't help you."
rrlund
01-11-2017 07:27:24
 Re: Not quite a in reply to Fatjay, 01-11-2017 07:11:29
Around here,Kubota seems to be like Allis Chalmers used to be. Dealers everywhere you look.
Dean
01-11-2017 06:55:39
Nice work.
I do not believe that the front R4 tires gear properly with the rear turf tires. I would check with a Kubota dealer to verify and change either fronts or rears to avoid long term damage to the front drive system.
Dean
Texasmark1
01-11-2017 07:34:24
 Re: Not quite a in reply to Dean, 01-11-2017 06:55:39
We've been bumping this subject a bit lately and I was interesteed in it for the following reasons. I am waiting on a set of 33x12.5x16.5 Titan turfs to replace my 12x16.5 R4s on the rear of a 4wd 24 hp Branson tractor. Circumferences are almost identical. Turfs are not like law mower tires. The tread is 11/32 and traction couldn't possibly be worse than the R4 rears they will be replacing for what I do.
I plan on leaving R4s on the front for added traction and stiff sidewalls and they will have adequate pressure to support the FEL.
I only use 4wd when necessary and if I am using it I am in a situation where traction is limited such that any ill effects caused by differences in grip should be minimized. From reading of others breaking front axles and such and seeing how they wound up in a situation where they broke the axle using the "auxiliary propulsion system" as a main drive is understandable. We'll see how it works out. Will post.
rrlund
01-11-2017 06:52:19
Fancy!
Married2Allis
01-11-2017 06:14:56
 Re: Not quite a "yesterday's tractor" in reply to Fatjay, 01-10-2017 19:35:29
Love it. Reminds me of a Good Humour ice cream truck. I'll have a Chocolate Eclair bar please!
WI Dan
01-11-2017 06:14:46
quote="Fatjay"
Not bad, looks like it will work good for you.
Will you clear-coat it also?
Fatjay
01-11-2017 06:07:15
3/4 x 1/8" angle iron and 1/16" diamond plate aluminum. Stainless would be expensive and heavy, was trying to keep the whole thing under 150lb.
John B.
01-11-2017 04:27:24
Is that cab aluminum or stainless??
47fivewindow
01-10-2017 20:20:47
ambitious project. Keep us posted
Fatjay
01-10-2017 19:52:02
Well I figure if it's going to fade, I'd like it to fade together. Plus I'll be storing it inside, so hopefully it will last a bit longer.
Gene Davis (Ga.)
01-10-2017 19:46:12
Most red and orange paint jobs fade to pink fast.
