Shop door seal finished
Alan K
Finally finished sealing up the sliding door on the shop. I used some pipe insulation as was suggested. I just slid some over some pipe. I used 3 different sections of it so it would conform to the floor better. There is a little bit of a slope on the concrete so it stays in place fine.
That looks like a good seal. I need to do my 2 sliding doors on my shop. Could you post a photo of the door half open showing the end of the seal?
And did you fasten the pipe to the door bottom and slip the insulation over it?
Thanks,
Richard in NW SC
I just used regular 1" pipe, I believe it was, and slipped 3 foot strips of pipe insulation over it to cover it all. I didnt fasten anything to the floor or the door so it can be removed when I open the door and dont have anything to wear out from driving over it.
I wanted to get it as tight as an overhead door which I was able to do, luckily. On
the top, I used the vinyl strip with a rubber strip like is used on garage doors.
The panels I put on with screws so I can replace a section without having to replace
the foam behind it as well. I wouldnt have minded an overhead door but for an extra
$3000 plus having to make the side wall higher to accommodate it, I figured I could
get by this way fine.
Looks real nice and functional. $3000 for a OH door? You need some Amish around. I just had a 7x11 R12 insulated door installed on my shop for less than $800.
Overhead doors can be leaky too if the rollers are a little sloppy. You have done a nice job on your door.
