Farmall exhaust lift
invcbl
Hello,
I have a complete exhaust lift off of a Farmall A that I was thinking of advertising for sale. What is something like this worth? Thank you for any info.
When you say complete that would be pressure valve which goes on the manifold then the pipe and linkage going to control valve then linkage going to steering post that would be a complete system if its all there and works price would be 350 providing every thing works and is all there. Lots of the control valves are frozen and the shaft doesent move. The pressure valves are the same way is it all there and working. I service and sell parts for these systems and have for many yrs so when someome says working system i wonder as very few still work unless they have been in use recently.
I may be too late, but I am looking for the following lift-all parts:
1. the entire pressure valve assembly with the valve rod and
2. the valve pipe and
3. the control valve rod
If you still have these, I would definitely be interested.
(quoted from post at 22:33:14 12/01/16) I may be too late, but I am looking for the following lift-all parts:
The lift was off a tractor that was used with a mower on it. I am assuming the parts you are asking for would be included as it was a working lift. Call 920-973-two four three seven if interested. Thanks
