JDownloader model la 1941
Dicejd41
New User
I am having a hard time getting the steering wheel off. I stripped
a steering wheel puller trying to get it off. Tried lubricate and
heat wheel won't budge. Any suggestions. I'll try anything. Thank
you. Dan
To get a stick wheel off I put on the puller, crank it hard, heat things up, crank it more, and spray on PB Blaster. Heat it up more. Then crank it more, leave it and walk away, come back the next day. Heat more, spray more, crank it more, leave the pressure on day after day, more heat and more PB.
Sometimes just the opposite will work-extreme cold instead of heat. If you live up north, leave machine outside and try again in mid January or when temperature is ZERO or below.
