Massey Ferguson power steering
jimmyzie
New User
Good day to all, As the turkey digests may I run a question past all of you tractor pros out there? I have a 61 MF 35 with power steering which worked fine until I let a fellow paint it and do a little work on her. One item was the seal down on the steering shaft was leaking so he replaced it, now it does not leak. However now it turns like power steering to the left ( and back to center) but no power steering to the right and it takes much muscle to turn it to the right. Any thoughts as to what the problem may be? Thanks and best regards, JZ
Wonder how deep he went into the steering gear?
Sounds like something is up with the directional valve inside the gear. Possibly was reassembled wrong, or something is jamming the valve, trash in a port.
