front axle needed for deutz allis 5220
chaddejong
New User
I have a deutz allis 5220 4 wheel drive that I just inherited from my father in law that passed away and I need to find a front axle for the tractor. axle bearing went bad and ruined the axle, housing has been welded on so im thinking it would prob be better if I could find a complete front end for it and just bolt it in but not having any luck finding any parts for this thing new or used.... any suggestions or anyone know where I could find one or know of a different front end that would work for me
Its a Hinimoto built tractor and as you have found out no parts support anywhere.I have a Massey Ferguson 220 4WD front end that I took off because it had a bad bearing in the front left wheel that might have the parts you need.You can also do what I did and replace the front with a 2 wheel drive front end,I took one off a 5020 Allis Chalmers and put it on the MF
(quoted from post at 19:51:48 11/17/16) My mistake..... it was Ward brothers..not walts tractors. You want to talk to James @ Ward brothers. 800-572-0297
thanks for the info, I will give them a try
well worse case scenario that was my plan for just a standard front end but I would like to try everything I can to get a front assist like it had.. how much would you want for your front end and where are you located at?
