704165m91 hydraulic pump
Rkh
Found all parts to put hydraulic pump on front of mf65 (using pto pump now). Found shaft,coupler assembly,adapter assembly and adapter collar that is described in agco parts list for the 99 loader. Can't find 704165m91 hydraulic pump that goes with it. Can anybody tell me a replacement pump that would fit. It is a 3 hole continental gas
is this the pump?
SAE A mount, CCW,5/8 or 3/4 keyway shaft, around 1.25 cubic inch/rev.
Try Surplus Center. Don't get a pump with the fittings sticking out the back of the pump, they will get bumped/broken.
Don't have pump years till looking for one. Here is picture of collar adapter that holds pump part #1401822m2.
The 3 countersunk bolt holes holds the pump mount bracket to the front end support of the tractor (indicated by the red lines). For the pump you need to measure the inside diameter of the center hole (indicated by the blue lines). You also need to measure the distance center to center of the two holes (indicated by the yellow line).
3 hole means it's a 3 hole mount for the hydraulic pump, some have 4. Sorry for the confusion.
