J D Dozer blade 534
pflum1
New User
I have a J D 534 dozer blade that came off a 4430 and would like to put it on a 4630. Will it work or what do I need to do?
It will work good, have one also--it has been a 4010-7020 and is on a 4240 now. You might have to put the pin in a different hole on the tube under the tractor. -------Tee
Remember a neighbor switching his, the only problem he had was one had a quad range and the other a powershift and one the front of the transmission hangs down lower than the other. Maybe the quadrange pto drive gear? 4430 to 4440.
That is right-On one of the tractors the clevis that attaches to the draw did have clearance problems. I took a grade 8 bolt and a spacer and it worked.---Tee
