OT-trans. filler tube
ohiojim
working on a T-bucket and have to re-route the trans. filler tube, anyone have a trick to bending the tube without kinking it ??
Slip a spring over it,(like a screen door spring) of snug-fitting size, You can buy a "kit" of assorted springs made for that too.
Track down a HVAC installer who uses a tool like this. It's used so that the copper AC line sets don't get kinked.
https://www.amazon.com/Yellow-Jacket-60325-Deluxe-Ratchet/dp/B00AY53JN6
Jim--Do you have any pictures to share with us? What are you going to run for a motor? I run a C-4 in mine and have a door under the passengers feet to check it. I was going to load a picture but can't for some reason.---Tee
Tubing bender??? Just a small manual one. I have several of them. They work well for bending coolant lines made out of aluminum and copper. Light steel lines as well.
