john in la
I am due a tire rotation on my pickup.
Goodyear Wrangler SRA tires if that makes a difference.
I have always just rotated my tires front to rear and rear to front same side keeping the same rotation direction.
Just the way I was taught years ago when I first started using radial tires.
I could even see if you had a bad front end where the tire was wearing on one side; taking the tire off the rim and turning it around then putting it on the other side of the truck. This would put the inside of the tire on the outside now but still keep the same rotation.
But I now notice a lot are recommending you use a X pattern when rotating tires. LF/RR and LR/RF changing the tire rotation.
Your thoughts on the subject.
