I have an electric starter on an old 8 HP Briggs, 23 FBC.
The starter operates on 6 volts.
Problem is the starter drive doesn't engage into the flywheel gear, just grinds without meshing.
I have to manually turn the starter drive gear into the flywheel gear and then hit the switch - then it will work.
Is this a bad starter drive?
