HELP!!!!!!!
Guys i pulled my 3 point off in preparation to work on it and last night I installed a new actuating cable because old one was very stiff. WEll it went up but it wont go down it is stuck all the way up!! HELP guys gotta figure this out!!!
If you're referring to 4020 rockshaft control cable do you have end(key 30) screwed on new cable the same number of turns as old cable and clamp(key 34) installed in correct location??? Have you attempted to change position of L/D control lever under seat?
For some reason I think you have to do an adjustment procedure anytime you change something on the 3 pt. linkage. The I & T manual gives the step by step instructions. I'd try this. It involves going in from the back with a socket on an extension. Make sure you tape or weld the socket on so it cannot fall off !
(quoted from post at 15:12:07 10/21/16) For some reason I think you have to do an adjustment procedure anytime you change something on the 3 pt. linkage. The I & T manual gives the step by step instructions. I'd try this. It involves going in from the back with a socket on an extension. Make sure you tape or weld the socket on so it cannot fall off !
IMHO simply changing control cable if performed correctly should not require any internal adjustments to L/D mechanism. There are more steps than ""one"" to correctly adjust L/D mechanism on a 4020
Its not like its trying to go down its just like locked in the upright position. ill try to
post a pic of where the rockshaft is positioned at the time. Thanks
