NEKS
This is off a JD wheel disk model EHIBI. Am wondering if JD still has this part in stock. This part is on the cross tube where the hyd. cylinder hooks up to raise it.
Looks like you got your money's worth, that way that top hole is wallered out with long use.
Have a local metal fab shop cut one out of 3/4" plate to match. If you want even better results have them put bushings and zerks in it!! Jim
I'll bet that you were not on a state road when it broke. See, your luck is not so bad. I expect that it could be made from 1/2 or even 3/8 stock, just a little bigger and built up for the holes, if it made it a lot easier to get it done.
Like others said, if JD doesn't have one, it shouldn't be too hard to fabricate.
BTW, a couple of years ago, JD still had a part in stock for my #5 sickle mower.
