34" power adjust wheels with 8 on 8 bolt pattern??
Eldon (WA)
Can anyone think of a tractor that used 34" power adjust rear wheels that used a stamped steel center with 8 on 8" lug pattern? My AC 6080 has heavy cast centers with 8 on 8, but would like to find a lighter center.
I don't know the bolt pattern but I worked on a ford 5000 with
power adjust rims and stamped centres. Can't think of any
others without cast, maybe a David brown model?
I saw a 6070 with 16.9x34.
6060 was either 18.4x28 or 15.5x38. Neither was particularly desirable. We put 18.4x30 on our 6060, and liked it much better.
(quoted from post at 16:46:31 10/13/16) I saw a 6070 with 16.9x34.
Well you can put just about anything on anything....I bought this set from a 6080 for $500 a few years ago and put them on my 175 Hi Clearance...now I need a step ladder to get on it LOL. Had to grind out the pilot about 1/16" as it was metric.
The 6070 was available with 16.9x34 from the factory, and I saw a new one at another dealer. No 6070's sold around here. I don't know what type of wheel center was used, but my guess is it's the same as the 6080.
I have seen late Ford 5000s and 6600s with 34" steel centers. Don't remember if they were power adjust.
Must be just the way I think. But You want a lighter center and at the same time have extra weight hanging on it??
Dont compute.
(quoted from post at 20:25:11 10/14/16) Must be just the way I think. But You want a lighter center and at the same time have extra weight hanging on it??
Dont compute.
No, the pics are just to show what I have....I had some $600 spacers/adapters made up for my JD 5525 that I sold...now I am looking at a JD 6000 series, but the tires are tall and narrow...I want to use the spacers I have to mount factory spec 34" tires. I would use these wheels, but the studs in my adapters are too short. I suppose I could buy longer studs, but thought if there was a thinner wheel out there I would go that route. I do not need the extra weight of a cast center. I really am surprised that no other manufacturer used a stamped 34" center with a 6 rail rim!
