Finally work is underway to upgrade the municipal drain through our other farm. Several neighbour's petitioned the township last year to upgrade it since the existing drain is only 16 inches and cannot handle the flow now that more land upstream has been tile drained. I was getting several blow holes on this farm which is on the lowest end of the drain where it empties into an open ditch, and the grassed waterway was being damaged. The drain being installed is a 30 inch by 4 foot long tile, the largest they can put in with a wheel machine The project involves two drains and about 5 miles of tile, draining over 1000 acres, costing about $700,000.Sure is an impressive line of equipment. Ben
