Ferguson tractor serial number
ou8125150
New User
Good evening!
I have what I was told is a Harry Ferguson TO-35.
The 2" by 3" plate on the dash is unreadable. Is there any other
way to determine for sure the model and year of manufacture on my tractor?
I am a complete rookie at this.
Any help is much appreciated.
Thanks in advance!
John in Dublin Texas
Z129A600 followed by A23P is raised lettering/numbering on engine block.
TO-3130 A on steering arm
All major parts have HF with circle around it.
There is a weird C with an L through the middle of the C on the block also.
I will need a carb rebuild kit and possibly a water pump and/or gasket and I don't want to order the wrong parts......
The Z129 engine indicates you have a TO-30. TO-35 had a Z134. I think they were made from 51 to 53. Post any questions on the Harry Ferguson board down below.
If it is a 35, it has 2 shifters between your knees. The tall lever on the left has 3 forward gears and 1 reverse. The shorter lever on the right has Low-Start-High. If it has one shifter and 4 forward speeds, you got taken.
(quoted from post at 04:30:05 09/29/16) If it is a 35, it has 2 shifters between your knees. The tall lever on the left has 3 forward gears and 1 reverse. The shorter lever on the right has Low-Start-High. If it has one shifter and 4 forward speeds, you got taken.
I definitely have a TO-30.
I did some trading and I have around 1100 bucks in it.
It runs okay, needs some maintenance, but a really cool little tractor.
Thanks for the help!
You didn't get hurt at $1,100. However, the seller either misrepresented the tractor or didn't know the difference.
